Option to disable RoomFit for Headphone output without needing to re-enable it for speakers everytime.
CraigShaw
With the excellent RoomFit levelling out the room modes, and now the EQ being able to superimpose the desired sound signature I think the Wiim Ultra is an amazing sounding device. The problem is, these settings are still active when I select headphone output. This makes them sound off as my ears don’t really need room correction! Can there be a way of the Wiim Ultra knowing which output is selected when changing the RoomFit profile and possibly the EQ/PEQ. Normally I would leave the EQ alone and turn off RoomFit whenever I switch to cans, then I would need to turn it back on when playing through an output that supplies my room speakers.
I guess some people may supply multiple rooms using different outputs and it would be nice to have at least the RoomFit profiles independently set per output.
Thanks for reading this!
  • Like
Reactions: d00
Upvote 2
isn't it possible to create a preset for such use case?
See the post in thread 'WiiM Ultra Firmware v5.2.725647 Update - Aug 8, 2025' https://forum.wiimhome.com/threads/...5-2-725647-update-aug-8-2025.7861/post-141626
You can create presets but you need to manually switch the preset whenever you change the output as it doesn’t do it automatically. So to listen to headphones, i need to manually turn off any eq from Room Fit etc. Then when going back to speakers, I need to go back and turn on Room Fit.
