Prevent Active Speakers From Auto Power-Off, using Periodic Ping
indispus
My suggestion is to add a feature that periodically `pings` the active speakers to prevent them from automatically turning off.
This can be achieved by sending an inaudible signal to the speakers after (configurable) X minutes of inactivity.
Due to EU regulations, most active speakers automatically power down after a few minutes of inactivity, requiring users to switch them back on manually. This can be quite annoying.
My setup: WiiM Ultra + Q Acoustics M20 active speakers - used for TV audio and Spotify straming.
My problem: When pausing the TV, for example, the speakers turn off automatically, even if the WiiM Ultra is still on.
Upvote 1
That would actually be a pretty handy feature. A small, inaudible ping every so often could keep the speakers awake without affecting the listening experience. Auto power-off is useful for energy saving, but it becomes a hassle when your setup goes silent for a moment and you have to wake everything back up manually. Your use case makes sense, and a configurable keep-alive signal seems like a simple way to avoid that constant on/off cycle.
"and you have to wake everything back up manually" -- Don't understand the manually part. As far as I know and have experience with a device with auto-off will automatically switch back on when a signal is present...
That is not the case for most active speakers. They just turn off and won't turn on automatically when signal is resumed.
Please give some examples as I'm not aware. My Genelec, KRK, Alesis & Neumann speakers all turn on again without pushing knobs or switches. My DAC does and also some other devices.
Which speakers do you have?
Here are two examples of speakers that turn off automatically, but won't turn back on:
- Q Acoustics M20
- Heco Ascada 2.0
- Q Acoustics M20
- Heco Ascada 2.0
Aha is see, poor implementation of an auto standby function but these are exceptions, the vast majority of speakers and other devices work as you would expect.
So this feature request should cover the described scenario and brings value to the WiiM Ultra.
Kodi has offered a similar feature for years. It’s incredibly useful because it prevents the subwoofer from dropping into standby during quiet movie scenes or tracks. Don’t you think it’s a total deal-breaker when a powerful bass hit comes in, but you miss the first few seconds because the sub was asleep?
As the WiiM team continues to improve deep subwoofer integration, adding a 'prevent standby' toggle would be a huge boost to the overall user experience.
