Brantome
- Oct 20, 2022
See Filter Export and File Formats in the HouseCurve Help pages https://housecurve.com/docs/manual/filter_exportCa
Where can I find these settings?
Thanks!See Filter Export and File Formats in the HouseCurve Help pages https://housecurve.com/docs/manual/filter_export
From the 'HouseCurve' screen after you take and save measurements, click the elipsis ("...") top right of screen, select 'Equalize', then click the settings icon at bottom of that screen and slide 'Max filters' to 4 to match your WIIM. You can adjust the frequency range to focus on areas of concern (I've been playing with restricting the range to where I have most problems to make the most of the 4 filters).Thanks!
I still can't figure out how to "set bands" in the Home Curve settings. I see 10 bands when I do a test. Would I just use the first 4?
Sorry for what probably are silly questions, I'm a novice with this.
Perfect! Thanks so much. Really appreciate your help.From the 'HouseCurve' screen after you take and save measurements, click the elipsis ("...") top right of screen, select 'Equalize', then click the settings icon at bottom of that screen and slide 'Max filters' to 4 to match your WIIM. You can adjust the frequency range to focus on areas of concern (I've been playing with restricting the range to where I have most problems to make the most of the 4 filters).
It will dynamically update the 'Equalize' screen with the resulting post EQ curve - makes it easy to see the effect of adding additional bands and how Housecurve optimizes based on how many bands you give it to work with. Housecurve convinced me I need more than 4 so I'm looking at other solutions for the DSP part unless WiiM adds more bands via firmware.
Roon has a lot of bands in its PEQ and you might enjoy the look and journalistic element of Roon.. I have it but very often can't be bothered to keep my laptop open just to listen to music...Wiim app + Qobuz is quick & easyFrom the 'HouseCurve' screen after you take and save measurements, click the elipsis ("...") top right of screen, select 'Equalize', then click the settings icon at bottom of that screen and slide 'Max filters' to 4 to match your WIIM. You can adjust the frequency range to focus on areas of concern (I've been playing with restricting the range to where I have most problems to make the most of the 4 filters).
Hmm I am using optical outEQ isn’t applied to Bluetooth or airplay output
Which same high frequency peak? Must have missed that bit. Did you select the correct mic in Housecurve setup?I get the same high frequency peak when using Housecurve and my old iPad and not necessarily through my Wiim pro plus. Will have to try other orientations too I guess
Sorry, I may have misread your post and made a wrong assumption.Hmm I am using optical out
Do folks test for different settings if/when rotating different speakers, or any other gear, into rotation? I get significantly different setting suggestions(which I suppose is obvious) for different pieces of gear. And since I tend to rotate various pieces in on a daily basis, I suppose having a custom curve available for each isn't a bad idea, if a bit anal.
