Hello fellow Wiimers,
I recently acquired a 2nd-hand wiim ultra and I'm having a hard time integrating it into my current setup. The issue is the subwoofer, no matter what settings I set it produces a disgusting rattling, distorted sound.
I have a Dali Trio AW8 sub which I connect through its sub in input to Wiim Ultra's sub output. (The rest of the system is two Kali Audio MM-6 speaker drive trough the optical output, no issues)
The dali sub is working fine in another setup driving with a yamamha amp sub out, love the sound! --> no issue
The wiim sub out is also tested with another subwoofer with the same sub-out --> sub-lfe-input route --> no issue
Here are my settings:
Wiim:
Crossover frequency: 80Hz
Sound level: +15dB (I tried all values within the available scale from -15 to +15, simply no sound below 0, and only timid rattling around 5-10dB range)
Bypass mode=off
EQ/Roomfit=off
Dali:
Crossover frequency: fully open at 150Hz
Level: at 9 o'clock position (tried all positions)
Conclusions:
I'm suspecting that the Wiim ultra doesn't outputs hot enough signal for the Dali. Based on my research the Wiim Ultra produces ~1Vrms signal (for comparison my Yamaha amp puts out 4Vrms) on it's sub out. So my 1st assumption is that the Wiim simply not producing enough signal to drive the Dali (input impedance 47 kOhm), hence this rattling sound.
The symptoms are improving when i use the Dali's line-inputs, the rattling sound disappears, but the sound still sound "higher" and not as controlled as it should be.
My 2nd theory (actually its chatgpt's
) is because:
"- the WiiM Sub Out may contain components around 0–10 Hz
- the DALI mono input is not AC-coupled
- this causes input instability / distortion
- this does not occur with Yamaha AVRs, because they already have infrasonic (high-pass) filtering built in"
I tried literally every possible sub settings in Wiim app, still no improvement.
If anyone has run into something similar, please let me know.
Wiim:
Bypass mode=off
EQ/Roomfit=off
Dali:
Conclusions:
