Remote wiim " plus" présélection
canard
Hello,
silly question:
Is it possible to use the arrow keys on my Wiim " Plus" remote to switch between presets and not be limited to the four available buttons 1-2-3-4 ?
Thanks in advance
Hello,
silly question:
Thanks in advance
You can't do that, but is this a request?🙂
That seems like a very logical use and request, doesn't it?
the possibility of navigating through our presets via these arrows....all 12 pre-selections available, not just the 4 direct access options...
:oops:
Will the next Wiim remotes offer more direct access to presets? Not just four (it's not a lot)...
:oops:
Yes, I agree. I seem to recall making the same request before. However, I think we need a new feature (or a new button) that temporarily disables the current control buttons. Also, on devices without a screen, there’s the problem of not knowing which preset you’re currently on. I’d like a 4th-gen remote with a small E-ink screen.
You can double press the 1-4 keys to get presets 5-8
Thanks!
That's something!
Direct access to 8 is great...
( I thought I'd already read something like that..)
( But the idea, even without an indication (maybe a future remote with a screen would let you know), of being able to navigate with the arrow keys seems quite useful to me.)
I'm a very old user... ( my mini..02/22)
who had so well "hidden", the first day ,the remote control... who never used it... ;-)
But a friend wondered about its use... I had to get it out again... And especially in my very simple use of my "plus"... it's very suitable if I have access to a little more than 4 presets...
Yeah, we know 😂
Did you know that if you press the preset button on the front panel of the Pro Plus repeatedly, you can cycle through presets 1 through 12? 🙂
P.S.: In my defense regarding the use of the buttons on the device, the device is quite hidden and inaccessible... but as for the remote control... I have no reason for that... my apologies. ;-)
