Resolving 24/192 not working via SPDIF
markovian72
Previously, I had 24/192 sampling working via SPDIF on my WiiM Mini.
Today, I went into the WiiM App and noticed that all content was playing at 44.1 and was confused... thinking maybe it was a bug in the latest firmware.
I changed the Output Resolution to a lower value, 24/96 and sound played thru my DAC -> Headphone Amp -> Headphones. But when I changed the Output Resolution to 24/192 no sound came thru... even though I heard the DAC clicking to indicate it was changing its sampling rate.
After reading another support thread, I decided to swap from the aftermarket optical cable I've been using back to the stock cable which came with the WiiM. I rebooted WiiM and my DAC, but I could still only get 24/96 to play sound.
I thought maybe the optical cable connectors weren't quite properly seated between the DAC and WiiM, so I re-adusted them and tested again. Still no sound at 24/192.
Finally, I thought that perhaps having the optical cable fairly tightly wrapped around itself could be affecting the signal... so I disconnected both connectors, swapped which connector went to the DAC & WiiM, and then reconnected everything, but wrapping the cable around in a circle much looser (i.e. greater radius). After another reboot of the devices I'm now able to get 24/192 when configuring in the WiiM App and playing music.
I just wanted to share this troubleshooting resolution in case anyone else runs into the same problem.
They definitely need to address this issue. I to only get 96k.
Devices that do not support 192kHz via SPDIF optical are common, least wise their warnings of questionable dependability are. Further, it could also be the optical front end of your DAC that may be gagging on 192kHz. Have you tried troubleshooting with connecting via SPDIF coax, which typically supports 192kHz…?
