Using the built-in mic on iPad or iPhone will not work well.I always have a problem with this calibration. It's better on the iPad than the iPhone, but it's still weak. It cuts my bass all the time. The sound is made as if I put a blanket on the speakers. Without life.
See a recent Reddit post below - I don’t know exactly how the curves were derived, but they attempt to compare iPhone, iPad and UMIK-1 microphones. I was surprised at the similarity, but UMIK-1 response appears flatter, and the difference is largest below 50Hz. Is the problem that iPhone and iPad mics just aren’t suitable for bass correction?I always have a problem with this calibration. It's better on the iPad than the iPhone, but it's still weak. It cuts my bass all the time. The sound is made as if I put a blanket on the speakers. Without life.
-Ed
No, that‘s wrong.Darko sagt, dass WiiM das Smartphone-Mikrofon zur Synchronisation mit dem Subwoofer nutzt. Ist das beim Ultra Amp anders als beim Ultra? Ich bin etwas verwirrt.
He was simply wrong/uninformed.Darko sagt, dass WiiM das Smartphone-Mikrofon zur Synchronisation mit dem Subwoofer nutzt. Ist das beim Ultra Amp anders als beim Ultra? Ich bin etwas verwirrt.
How did you run room correction? The RoomFit profiles are saved in the same page that you run the room correction fromAfter the last update (Wiim Pro), my calibration works (Room Correction), but the resulting profile is not saved anywehere.
I did a ticket and received an explanation about 'RoomFit' etc BUT There is no RoomFit tab on my Wiim pro app.
What am i missing ?
Sometimes the WiiM Home App updates don't appear in the update list but when you search for the app it shows an update is available. It's a mysteryI had to manually update the app from Google Play, not I see the buttons.
I am used with automatic updates, that is why I was confused.
I get the same but what is happening, as I can see, is that the lower frequencies is getting under controll according to the room and that sounds flat if you are used to the uncontrolled bass.My biggest issue was that everytime I ran RF, I was having all the bass sucked out.
First of all the MMM process starts with the right smartphone orientation. You must twist its orientation, the bottom microphone must point to the loudspeakers, For this purpose the app itself twists by 180°. Now the GUI is upside-down and you can twist the smartphone and continue the process with that orientation,
The first sweep is the usual low-to-high frequencies run. For this the smartphone should be exactly at the place where you normally are sitting.
After that a white (or pink?) noise starts for one minute. I recommend an ear protection. During this audible noise you move the smartphone randomly around the usual listening area, let's say +/- 20 .. 30cm in all directions.
Finally you get a result that (in my case) looks very different to all former measurings. Frequencies that I never thought of before suddenly are recognized and compensated. In my case even around 5kHz was a strong mode, I assume the many glasses in my car, whatever.
The result is the best I ever had in my car (and I am dealing with this subject for approx. 40 years now ..)
I don't quite understand the difference.Quick question: Should the microphone be pointed directly at each speaker, or kept in the sweet spot for both channel measurements?
