There are only a few servers that support classical music, as has been mentioned before.The best way to describe this is to say that, with possibly one exception, music servers simply don’t understand any organization that requires the name of the composition and a list of albums that contain it. That’s how you think when selecting music. If you have duplicate performances, you need to see the conductor or the soloist.
To work around this, I put albums in folders.
This is not a problem if I can browse folders.There are only a few servers that support classical music, as has been mentioned before.
Even then you need to use the correct tags.There are only a few servers that support classical music, as has been mentioned before.
That’s not a problem. I can fix tags.Even then you need to use the correct tags.
A.lot of recent work has been done regarding Classical tagging in Logitech Music Server. I am not trying to push you in that direction just letting you know it existsThat’s not a problem. I can fix tags.
Not always, some servers allow mapping.Even then you need to use the correct tags.
The moment Sonos restores access to media servers, if it does, I will have a look.A.lot of recent work has been done regarding Classical tagging in Logitech Music Server. I am not trying to push you in that direction just letting you know it exists![]()
With LMS you would bypass the Sonos app and play to the Sonos players as UPnP devices.The moment Sonos restores access to media servers, if it does, I will have a look.
I could do it, but I have eight family members who visit. This is why Sonos is still in businessWith LMS you would bypass the Sonos app and play to the Sonos players as UPnP devices.
We're going around in circles now. If you want to use the Sonos app then you're stuck with Sonos indexing (folders) or Plex.The moment Sonos restores access to media servers, if it does, I will have a look.
Not true Sonos used to find and use UpnP servers.We're going around in circles now. If you want to use the Sonos app then you're stuck with Sonos indexing (folders) or Plex.
Which ones? Certainly not LMS or MinimServer. I already mentioned that AssetUPnP and Windows media sharing were unusable.Not true Sonos used to find and use UpnP servers.
I have the old app, but the page where you enable UPnP is grayed out, and says to update the app. Sonos hasn’t said specifically what services will be restored. Perhaps we’ll know more in a few weeks.Which ones? Certainly not LMS or MinimServer. I already mentioned that AssetUPnP and Windows media sharing were unusable.
If you have an Android device you can still use the old app.
I also use Emby (a DLNA server) which has similar services to Plex. It has a recommended structure but is more permissive.My system originated in iTunes. It’s not complicated. Album or CD by name. Followed by tracks in numeric order. Multiple CDs can have the same name, but there’s CD number.
So when I want to play something I need to be able to browse folders.
I've just reinstalled the old app and wow, I hadn't realised they'd crippled the old app too! Disgusting behaviour.I have the old app, but the page where you enable UPnP is grayed out, and says to update the app. Sonos hasn’t said specifically what services will be restored. Perhaps we’ll know more in a few weeks.
