Silicone case for remote control
satek77
Remote control is very fragile and susceptible to scratches. I can't find the case anywhere for them.
Upvote 0
I seem to recall someone on the WiiM Facebook page saying they’d used a cover meant for the newest larger Amazon fire tv remote.
Edit: maybe something like this, but I haven’t verified how good a fit it is, but I guess it’s cheap enough to try
Or this one with cat’s ears 😂
It feels quite rugged to me, and seems no more likely to suffer from damage, or scratches than any of my many other remote controls. What exactly are your concerns for its wellbeing, and longevity.
I'd like a case to make the remote less slippery and change the color.
Which WiiM Remote Control do you think is slippery, and needs its colour changing? 🤔
A silicone case would tend to make the remote control more slippery, rather than less. 🤔
For the WiiM Remote 2, you might want to try an inexpensive silicone case for the Apple TV Remote.
1474-jpg.30048
The WiiM Remote 2 is slightly longer, but it should fit if you cut the top part of the case.
It's a Voice Remote 1 that comes with the Ultra. Perhaps over time it gets less slippery.
