EDIT:
I sent a ticket this morning as the dropout occurred again.
Ticket:510814
I will now attempt a factory reset as this issue is only happening with a very small percentage of users.
Yes, I have the same problem as you now.
Have you tried these two?
- Unplug the power cable and plug it in a few minutes later
- Re-pairing the remote
The first disconnection occurred after running RC many times. For some time now I have had no sound on Spotify connect after RC. But this is the first time today that I have had this kind of drop out.
I have the same problem with playback from Spotify, Amazon, and phone storage, and it appears to be an Ultra issue, as the problem does not occur with the WiiM amp.
I have tried rebooting several times, but each time I start up the symptoms get worse. I thought the remote was malfunctioning, so I re-paired it. I then unplugged the Ultra's power cable and turned it on a few minutes later.
And now it appears to have worked, with no drop out yet. I will have to wait and see for a while longer.
