Hi.On Spotify when I select the Wiim Pro to connect through the WiFi, the music from Spotify only plays through my phone and not through my bookshelf speakers. I never had this issue before. What can be causing this?
Reboot your router and WiiM device, then try turning off wifi on your Spotify app device, then back on.hello to everyone;
I am writing from Turkey and I have been using Wiim Pro for 1 month. I had no problems until yesterday, I had the same problem last night.
I did the following;
* I turned off IP6, it didn't fix it
* I deleted spotify and reinstalled it, it didn't work
* Restarting the Wiim app did not fix the problem
* I deleted the Wiim app and reinstalled it, but the problem did not go away.
What else am I left to do?? can never be used like this :/
I’m not aware of any firmware updates to the Pro in the past few days, so sounds more like something in your network environment
Have you submitted a ticket via the feedback section in the Wiim Hime app? This is a user forum and not trawled by the support team for issueshello everyone again, I am really sad (
I tried everything suggested to me but nothing changed, I want help from the support team, it is not possible to continue like this.
If the DNS server is turned on in the WiiM app, try turning it off.hello to everyone;
Maybe also turn off IPV6 as I see that has helped another user with Chromecast issues - it may not be related, but worth a tryThank you my friend, I will try it, I hope it will be a solution.
I turned off IPV6 and tried it, my friend, nothing changed.Maybe also turn off IPV6 as I see that has helped another user with Chromecast issues - it may not be related, but worth a try
I've used Spotify yesterday and this morning with my Pro. No problem at all. I think the problem may be more on the Spotify side then. Whenever I had connection problems with Spotify in the past it was their fault.
I agree with @MrSoul4470, but just in case, have you already tried a factory reset of your WiiM?So you may be right, it just happened without any problems. I reset Spotify, deleted it and tried reinstalling it, but it didn't work. Likewise, I deleted and reinstalled Wiim Home, the result did not change, I am very curious as to where the problem is??
There's a reboot function in the WiiM Home app device settings. I'd normally advise rebooting your router at the same timeI agree with @MrSoul4470, but just in case, have you already tried a factory reset of your WiiM?
Today my new toy (AVR) arrived, and when I first tested Spotify Connect, but there was no sound. In conclusion, I solved it by system rebooting the AVR. The WiiM may be able to system reboot from the web using the IP address as well, but I don't know how to do it. So factory reset is an alternative.
