Static and Noise on New Unit
SpaceCadet65
Brand new unit. I have it plugged in to my Cambridge Audio integrated amplifier via analog AUX out. The minute it was powered up I heard static/digital noise coming from the speakers. It continued throughout the setup procedure. The static noice changes in sync with the light on the front of the unit. As it flashes, the quality of the static sound changes. I could get no audio output from the unit during the latency test while doing the setup. I am using the supplied power cable and power adapter in my surge suppression power strip. I've also moved the unit around to see if it was interference from another source
Is this just a bad unit, or is there something else I should try?
Thanks
It's a setting available in the app, but not an app property. You configure the digital output of your device (the hardware) to either transmit at 192 kHz or 96 kHz sample rate.
If the cabling and devices further down the chain are happy with that or not.
