Here, I googled it for youIs it still crickets here?
Thanks, I just applied for a beta test.Here, I googled it for you
Ongoing Beta Thread 'Beta Test: Simultaneous USB out and Sub out'
Hi WiiM Community,
We are seeking beta testers for the simultaneous USB Out and Sub Out feature, available exclusively on WiiM Amp, WiiM Amp Pro, and WiiM Ultra.
How to join this Beta?
If you are interested in beta testing this new feature, please provide your Wiim Forum username and MAC address in the Beta Test link.
Thanks!
WiiM Team
- WiiM Team
- wiim amp wiim amp pro wiim ultra
- Forum: Beta Testing New Features
You could probably contact wiim and ask to be whitelisted if it doesI'm currently using the USB out to my headphone amp and the line out + sub out to run my speakers.
If they implement sub out for USB, I hope they include an option to make USB (or each output) individually configurable for full range or crossed over - otherwise this breaks my configuration...
You can still manually disable the subwoofer when you use headphones. I agree that options like that should be part of smart presets.I'm currently using the USB out to my headphone amp and the line out + sub out to run my speakers.
The whole point of the current configuration is that I can change from headphones to speakers with the front panel without having to use my phone and the Wiim amp.You can still manually disable the subwoofer when you use headphones. I agree that options like that should be part of smart presets.
You obviously aren't using EQ or room correction then. Hopefully smart presets will cover all of these options. I won't hold my breath thoughThe whole point of the current configuration is that I can change from headphones to speakers with the front panel without having to use my phone and the Wiim amp.
Tried it yesterday with my Chord 2Qute dac but my subwoofer still doesn't work (also installed an update first).Is it still crickets here?
That feature is still in beta.Tried it yesterday with my Chord 2Qute dac but my subwoofer still doesn't work (also installed an update first).
Same hereThanks, I just applied for a beta test.
I am using room correction - I have EQ setup on a per input basis so the optical input from my PC does not have EQ but the USB/Wifi input does (I use headphones almost exclusively for gaming)You obviously aren't using EQ or room correction then. Hopefully smart presets will cover all of these options. I won't hold my breath though![]()
