SKApretto71
Valued Contributor
- Oct 23, 2024
Hi everyone,
Hope the winter holiday season is going great!
I'm in search for a basic clarification: if I set the Fixed Volume Output in my Ultra to 'ON' I know the volume will be set to 100. But will it still account for the Volume Limit value, or disregard it?
As an example, if if ON and the Volume Limit is 50, will the output volume be less than if it's set Volume Limit to 90, or will be alike having set Volume Limit to 100, no matter the setting in the app?
Reason to ask: I have a DAC + Preamp + Power Amp connected to the Ultra but full volume will break probably the speakers. To prevent I'll like to cut max volume to Ultra so that even maxing the volume in the Preamp is still safe output wattage.
The other option is just use the Ultra for the Volume and skip the pre.
Thanks!
Thanks!
