Variable and fixed output?
Hollywood
Valued Contributor
I see that you can set the output volume on an Ultra per source (I think). What I was wondering is if you can set whether the output could be set variable or fixed by source. I am guessing some here would suggest just setting the volume all the way up, but I want a setting to lock out changing it on the WiiM as would be that "fixed" setting
Example, if I want to play from WiFi or other streaming service, I would want variable output controlled by the WiiM Ultra. When I play from my piCorePlayer touchscreen I would like the Wiim Ultra to be 100% (fixed) and I would control the volume within the pCP system (screen, pCP IR remote, or Material Skin from a tablet or phone).
Is that possible?
Thanks!
Yes, one could, but 100% variable is the same as fixed, just that it can be altered later!
At least with variable you can change the volume (fairly) quickly if needed in multiple ways without having to get into the specific app screen to disable fixed.
(This isn't really aimed at you, Slarti, just replying to your comment.)
True but the OP wanted fixed and not just variable set to 100% 🙂
