Ultra Power On Volume?
JeffB
Location
NC
Is there a way to set the Power On Volume on the Ultra? I would like to set the volume low at powerup so you don’t get blasted if the previous session was loud.
My Yamaha RN800A has that feature and its convenient and necessary with digital controls. In the Analog days I got in the habit of turning the volume knob before powering up.
Thanks All!
Thanks All!
I’ve requested this feature several times, but it hasn’t been implemented yet. It probably won’t be implemented in the future either.
For now, there are a few workarounds.
1. Use a preset to lower the volume.
Get into the habit of pressing the preset button on your remote first thing every morning.
2. Use an Alexa Routine.
Create an Alexa Routine to lower the volume at the same time every night. You don’t need an Echo device. This is the easiest method—anyone can do it with just an Amazon account and the Alexa app.
I forgot one more thing.
3. Use Ultra’s alarm feature.
Use Ultra’s alarm to lower the volume every night or every morning. You can also play a silent track.
Thanks Wiimer! It will take some habit forming but its better than nothing.
