TinnitusMaximus
- Oct 30, 2024
Hi all,
I have a few questions about my use case for the Ultra, which I am very close to purchasing.
My only feature gripe with the Ultra is no PC USB input, like in the Bluesound Node Icon, for example.
So if I want to connect my PC to the Ultra I would need a DDC/ USB bridge OR a dodgy USB to optical converter into the Ultra's optical SPDIF input. Unless there is another way?
I intend to use the Ultra as below:
Ultra (as streamer/preamp/EQ/Room correction etc.)>DAC(Gustard A26 with fixed output) balanced output> Headphone Amp > headphones
Ultra > DAC (line out) > Power amp (Roksan K3) > Passive speakers
1. Will the above use case work?
2. I also have a powered subwoofer I might want to connect to the Wiim. Will that work as well with the above?
3. Will going to an external DAC remove or negate any of the EQ/Room correction/DSP stuff that the Ultra is doing?
4. Any advice to connecting a PC with only USB out to the Ultra?
I would greatly appreciate any advice.
Thanks!
Thanks!
