No, not the Pro+. WiiM stated that a future Pro would have a USB-c digital out.What upcoming product ? Do you mean the Pro Plus ?
Yes, it maybe a year from now.No, not the Pro+. WiiM stated that a future Pro would have a USB-c digital out.
I don’t recall WiiM being as specific as USB-c, iirc they‘ve just said USBQ. for WiiM staff: Is the upcoming product with USB-c digital out UAC2 compliant?
These days... anything other than USB-c makes no sense.I don’t recall WiiM being as specific as USB-c, iirc they‘ve just said USB
USB on all Schitt dacs is great, probably best implementation under $3000. Trying to convert an optical to usb does not get good results. Future USB output would be great, i don’t care what dac chip is used, i wouldn’t use it. It would be a great streamer under $300Because SPDIF is one way with no feedback error correction. USB into ports designed for DACs like Schiit Unison have signal integrity advantages.
but what would be the interest for you (I also imagine that you already have a wiim (?))?A basic streamer with the Pro specs, sans internal DAC just adding a USB-c port out should be less than $150.
so your talk about "usb only" doesn't make sense... the contribution of usb for what not and it will do... but 99.99% of dacs have coaxial or toslink... not much usb...A fairly large market of people with separate DACs… yes I have multiple WiiM products but would prefer to have a Pro with a clean USB-c out port.
Not usb only… Spdif and other output of course.so your talk about "usb only" doesn't make sense... the contribution of usb for what not and it will do... but 99.99% of dacs have coaxial or toslink... not much usb...
""usb only""" why?
ps
machines for a niche market "a la audiophile" cheaper .. will be new and wiim will be very stupid
ps bis
on which usb-coaxial and dac sources did you find a superiority of usb over coaxial?
"niche"....lower production volume..more expensive...Not usb only… Spdif and other output of course.
you changed your "usb only", it's good but makes my point even more illusible.. it's not nice, and I don't need that to look like an idiot ... ;-))
so then...why this "usb"?
do you prefer it for use in direct comparison to coaxial at constant condions?
what specific cases?
Look if you don’t like usb don’t turn us like you that don’t want/like. Each one of us has its own personal preference. Usb is one of the most requested feature. It’s standard connection to modern home audio replacing legacy coax and toslink much like hdmi replace component video connection."niche"....lower production volume..more expensive...
you changed your "usb only", it's good but makes my point even more illusible.. it's not nice ;-)
I don't understand...I suppose you ought to know. But what about the current Pro with just usb added? 20cents more ok?
I am being facetious to counter your WiiM marketing insider plan.![]()
seemed to me to have read a "usb only at 150dollars"...(thanks to the economy)..explain my reaction..Where did I write usb only?
Above I wrote …adding… not only, or subtracting. Just for the record.
