I used RoomFit for the first time and the process was pretty easy. But I have a question about how to know if it is being used or not.
In the RoomFit Dialog it says RoomFit is on and I select the correct profile to use.
However, when I go to the playing now screen, the equalizer icon on the bottom right says Off. If I click on that I can select either EQ or PEQ, but there is no option for RoomFit. With Roomfit On, does the equalizer icon do anything? It seems like it should have a Roomfit option to select in addition to EQ and PEQ, without having to go back into the RoomFit dialog.
Any help is appreciated. Thanks.
