Witterings
Valued Contributor
- Nov 1, 2022
Where the WiiM's placed it always gets a weak WiFi signal / warning whilst every other phone / tablet in the same place is showing a strong signal.
Does anyone know how the WiiM measures the connection, is it like a phone where it just indicates how strong it is to the access point it's connected to or does it measure the throughput / connection speed does anyone know?
I have tried connecting a 2nd WiiM in case it was the device itself but that also had a warning / weak signal.
To further explain what I'm asking ... the internet comes into the house and is attached to a router which I'll call point A ..... there's a powerline / range extender in the room where the WiiM is which I'll call Point B.
If your phone is connected to point B it only indicates how strong that connection is between the phone and point B and doesn't take into account how strong the connection is between points A and B so it might be telling you there's a very strong signal but the overall connection and speeds may be poor.
Is it the same with the WiiM or does it actually measure the overall connection and internet speed rather than just the connection from the WiiM to point B does anyone happen to know.
