Speakers built into wallpaper. The wallpaper should have album art printed on it in my humble opinion!standalone speaker for surround channels
I would strongly suspect that this would not be considered by WiiM.I am still looking for a WiiM AVR or more precise AV processor and wanted to ask whether there are any plans in this direction.
Such a product could include features like:
Amplification could than be realized with some of the superb Vibelink Amps or a dedicated 8 channel amp.
- 4 to 5 HDMI inputs
- 2 HDMI outputs
- 8 analog outputs and up to 16 digital outputs
- Flexible channel routing and multi-way crossovers
- Per-channel parametric EQ
- Support for Dolby Atmos, DTS:X Pro, IMAX Enhanced, maybe Auro-3D
- Maybe optional Dirac Live, up to ART
Is this something that might be considered for a future WiiM product, or are there any plans you can share?
a little "tired"...I²S, everything else is pointless? Your humour might occasionally go by unnoticed, but not this time.![]()
What you ‚demand‘ and ‚require‘ are not really features on a consumer device.a little "tired"...
(And my previous long message was ironic, of course, but it wasn't understood...... "the need", "I would like", for lemo Camac sockets etc etc"..I should have also demanded a mini binder for Sym as well, and removed the "berrrrkkk" RCA connector to save space for them.)
Damn... I was still being sarcastic... and there's no... it just doesn't work...What you ‚demand‘ and ‚require‘ are not really features on a consumer device.
I suggest you go looking in the studio hardware section. Sorry, but you‘ll probably have to spend a wee bit more, which I am sure you are aware off.
Yeah, but better - more like a Volumio Rivo+.Eversolo T8 you mean?)
Simple...
I m require:
just a mini streamer, high-performance quartz crystal, external (upgradable) power supply, and just one i2s output (my DAC is there, and the rest is useless and of little interest).
In the end, a product that might be only slightly more expensive than a mini...
high-quality and truly useful...
Everything else is pointless...!
I can't see that happening.A 12 inch/300W version of the WiiM Sub Pro.... with more or less the same measurements of the current version.
Why ?? I mean, the measurements constraints can be relaxed but, why not a sub with a bigger woofer and the same integration to the WiiM ecosystem ?I can't see that happening.
It would need to be considerably larger in size and weight, but could be done.Why ?? I mean, the measurements constraints can be relaxed but, why not a sub with a bigger woofer and the same integration to the WiiM ecosystem ?
I’m with you on the EQ/RoomFit, but not the subwoofer support.I‘d like to see a discounted model without subwoofer support and without EQ/Roomfit.
It should cost about half of the regular models since 90% of the personnel cost will be for the development and implementation of those non included ‚features‘.
If you have decent (and big enough) loudspeakers and and amp that can really drive them you don‘t need a sub for true sound reproduction in a home environment. Adding a sub to such a system is mere straining after effects.I’m with you on the EQ/RoomFit, but not the subwoofer support.![]()
