And a bigger screen (cf. The node icon)I will keep it simple
A WiiM Ultra Pro:
- With an external power supply
- Be able to playback DSD files
- Balanced Output
Yes, A bigger screen would be beneficial when using the Ultra in a desktop situation, but having no screen if placed in an equipment rack that is more then 10ft/3M away.And a bigger screen (cf. The node icon)
The forthcoming WiiM Vibelink Amp might fulfil that wish.and a wiim amp that exactly matches the ultra…
losing a DAC/volume option ....for an expensive screen just for an accessory vumeter....surprising idea... but expliciteI would like to see a companion amp for the ultra without the dac section. Just a pure analog preamp, no volume control. Added bonus would be to have the same glass front as the ultra but with one wide display or 2 displays side by side for a L/R meter.
What about all the owners of other WiiM devices that might want to benefit from a better DAC section than they currently have, would they be left out in the cold? At least with the vibelink, it covers all bases.I would like to see a companion amp for the ultra without the dac section. Just a pure analog preamp, no volume control. Added bonus would be to have the same glass front as the ultra but with one wide display or 2 displays side by side for a L/R meter.
Presumably you mean "pure analog Power Amp" not "pure analog preamp"I would like to see a companion amp for the ultra without the dac section. Just a pure analog preamp, no volume control. Added bonus would be to have the same glass front as the ultra but with one wide display or 2 displays side by side for a L/R meter.
yes that was a typo. i will fix that if i knew how toPresumably you mean "pure analog Power Amp" not "pure analog preamp"![]()
Power amp not preampI would like to see a companion amp for the ultra without the dac section. Just a pure analog preamp, no volume control. Added bonus would be to have the same glass front as the ultra but with one wide display or 2 displays side by side for a L/R meter.
And re the VU meters and display screen , wouldn’t the signal need to be digitised for those (unless you want physical analogue meters) and wouldn’t that have the risk of potentially degrading the audio?
I think WiiM have taken a sensible approach with the vibelink targeting a wider audience.
I don't believe he called your post is stupid. Here is a user community. Anyone can suggest their ideas, but it is also a discussion forum.there is the vibelink so there is already a product for those wanting a better dac. I think its possible to add meters digital or analog without degrading the signal. I thought this was a place to post stuff we would like to see without someone other than wiim saying no your idea is stupid?
