D1N0
Senior Member
- Apr 30, 2023
for less than $200A pure streamer with a shielded very good clock, without DAC and Screen. USB + i2S as outputs and toslink as input fromTV(by pass)
May be you can rise a bit the final pricefor less than $200![]()
An audio-quality focussed Streamer/DAC/Headphone amp that can act as a Pre-amp if needed. Basically, a one-box equivalent of a Wiim-pro, a Topping E70 Velvet and an SMSL SP200 headphone amp (brands and model numbers given as a reference for desired sound quality, nothing else). Must have balanced headphone connection and true balanced XLR outputs controlled by a analog-domain volume control.
Max 250. Like a better argon audio solo with tidal connect. If no dac included it should be equal or better than ifi zen steamMay be you can rise a bit the final price![]()
Wiim, can we please get an insight information on what connections it has?
Hi Wiimer,WiiM is a device that connects to a network. Therefore, their partners are preferred by companies that are reliable for consumers.
Also, I think Linkplay is still immature as an audio manufacturer. For example, the WiiM Pro's coaxial terminal received a lot of criticism.
In the same way, T and S are immature. The sound quality (or measure) is may be good, but the quality and functionality of the product are not enough.
I think what Linkplay needs now is to learn from companies with deep knowledge of audio and create a highly complete audio product.
I'm sorry, my English skills are immature, so I don't know if you can answer your questions.
I believe the coax issue related to the limited space around the recess.Hi Wiimer,
Thank you very much for your comments.
Regarding the coaxial issue, please kindly help elaborate more so I can follow up with our product team.
With the upcoming WiiM Pro+, we plan to address the audio quality complaints for the analog audio output and input. I hope we learn it fast enough. Please stay tuned!
Hello wiim, does this streamer has usb, sub out with bass management and room correction? Thanks!Hi Wiimer,
Maybe, but consider their main slogan (I'm assuming it's the main one, as it's top of their website!"The name of the incoming product wiim pro+. I wish wiim would provide 2 wiim pro+ with dac and without. Majority of the people buying streamer would use their dac of their choice.
Thank you so much.Hi Wiimer,
why?USB Audio Out
Hi Wiimer,Thank you so much.
As for coaxial, Mr Ee is right. I talked about the terminals embedded in the panel. Audio manufacturers usually don't make these mistakes.
But I'm not blaming you, I'm hoping for you. I think your team will be able to make better products in the future.
I enjoy imagining the long-term future of Linkplay and WiiM. I am interested in what the company will be like in 10 years.![]()
No, they’ve already said it’s got a better DAC and will have improved digital to analogue conversion. Nothing more. For your particular feature combination, you’ll need to wait a few models further down the line I’d expect, particularly for room correction.Hello wiim, does this streamer has usb, sub out with bass management and room correction? Thanks!
Just improve internal dac and no additional connections? I’m not replacing my pro.No, they’ve already said it’s got better DAC and will have improved digital to analogue conversion. Nothing more. For your particular feature combination, you’ll need to wait a few models further down the line I’d expect, particularly for room correction.
