WiiM’s MultiRoom auto
d00
Active Member
Hello! I have a question. Is there any option to automate the WiiM multiroom function so that I don't have to enter the application to create a Multiroom connection?
I have 1x Ultra and 1x Mini. I want to make it so that when I play something from WiiM Mini, it automatically makes a MultiRoom connection to WiiM Ultra. No app touch.
Is it possible?
Do you use the Mini for anything else?? If not, setup your Multi-room Group and leave it...
Or is it that you are occasionally using the Ultra in another group??
Could be they also want to use the ultra on its own, and they may be using the Mini as an airplay target. If the devices are in close proximity, the Mini's optical output could be cabled to the ultra's optical input with auto-sensing switched on.
Either way, we need more information from the op...
Yes, I mean AirPlay endpoint. I tried to use it after the optical cable, but the auto-sensing does not work for me if there was an HDMI input before. And I mainly use HDMI.
I also tried to create a group of devices for multiroom, but after some time the group resets and the devices are not linked again.
Yes, I believe hdmi and optical share some internal circuitry. You might want to try the Mini's rca out into the ultra's line in - don't know if you'd notice a great change in quality depending on what the Mini is receiving over AirPlay.
