WiiM Mini with Pro's Multiroom Resolution
Witterings
Valued Contributor
It's been a while since I've looked at this, going back ages ago, the Mini wasn't able to play Hi Res 24/192 in a multiroom setup I belive as the hardware couldn't deal with it so there was no upgrade
If you now have say 2 Pros and a Mini in a group, firstly will they work together and do you have to change any settings or will they just default and play to the lower resolution?
I haven’t had time to set it up again but will have another go hopefully tomorrow. I guess devices being out of sync is only really an issue if one is in earshot of another though?
  • Like
Reactions: dtc
I’m not sure if Alexa MRM groups are also constrained to 16/48 too - that’s all I’m seeing grouping three WiiM devices together. Plus the WiiM home app no longer seems to show what’s playing when I use Alexacast from the Amazon music app to that MRM group. I’ve submitted a ticket to WiiM
Are they all Pros or higher and have you checked if they're set to play full res in the settings Can't remember where it was as over 1+ yrs now but I had to keep changing it with the Mini's depending on whether I was playing to a single device where it'd do 24/192 or MRM which the Minis wouldn't ..... this was the only reason I upgraded them all as constantly switching it back and forth was a pain.
Yes, all checked, Mini not involved.
Of course, have done since its release.
Thought you probably would but thought I'd check just on case .... I would raise a ticket then, it worked fine for me for over a year, although I've now moved away from Amazon Music and use a different streamer for my critical listening now as well.
