Brantome
- Oct 20, 2022
The WiiM remote is not compatible with Harmony. You might find some entries for WiiM in the harmony database (I don’t know how they got there) but they don’t work.I use the Logitech Harmony as a "one remote does all" solution but of course it's not the cheapest of solutions. You can run a "profile" of different devices depending on your activity so in your example, while watching the Shield the remote would still play/pause etc but the volume control would be directed at your Wiim (yes it deals with IR and bluetooth remotes).
Now of course they're no longer available as a new product, you may be able to pick one up 2nd hand or there are other solutions but I can't comment on how effective they are.
I'm not looking forward to the day my remote dies or Logitech remove the back end support.......
