WiiM Amp Ultra Firmware v5.2.739555 Update - Dec 23, 2025
Please review the WiiM Amp Ultra update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
5.2.739555 (In Progress)
Release date:
Dec 23, 2025
General Improvements:
  1. Wi-Fi: Stronger connection stability; improved compatibility with Wi-Fi 7 routers.
  2. Audio Spectrum: Added Audio Spectrum visualization. Better timing alignment with playback.
  3. Queue: Better track order retention in shuffle and faster queue operations across NAS/USB/Samba/Local, TIDAL, Qobuz, Radio Paradise, YouTube, Deezer, and SoundCloud.
  4. Multi-room: Improved multicast logic for more reliable discovery/connectivity; reduced stutter when using Bluetooth input.
Music Services:
  1. Qobuz: Stabilized progress bar; fixed shuffle dropouts, playback-mode mismatch, and missing artist/track metadata.
  2. Soundtrack: Updated SDK; fixed disconnects when renaming the device during playback.
  3. Amazon Music: Fixed position reset after back-to-back seeks.
  4. USB Library: Fixed disappearing album art.
  5. TIDAL Connect: Fixed playback interruptions after ~1 hour.
  6. TuneIn: Now consistently selects the highest available stream quality.
  7. Radio: Resolved failures for certain station formats.
Bug Fixes:
  1. Google Cast: Device now retains its assigned room after reboot.
  2. VU Meter: Restored operation with Dolby audio in multi-room playback.
And @cooky560 do both/either of you use the PEQ and/or RoomFit™? I wonder if LinkPlay implemented some negative pregain to eliminate digital clipping if there’s any sort of PEQ or room correction boosts.
-Ed
I'm not using room fit or the EQ, Perhaps if I turn them on and off, it'll resolve this issue? it's very strange all the same.
I do change the volume very frequently, so my auditory memory might not be calibrated that finely, but I don't notice any difference when watching TV. 🤷‍♂️
Also all pre-gain settings remained unchanged.
Me too.
My Amp Ultra's base volume is set to 82%, but it sounds the same as usual.🤔
Perhaps I’m weird but I’m the sort to configure my gear how I like it then leave it alone. My living situation means bothering the neighbours at 2am is not a worry.
So I am surprised when anything warrants a volume change.
I listen to mixed track playlists. There are substantial volume changes between individual tracks. I probably adjust volume on average every other track played.
-Ed
I have four Ultras.
One is right now turned off, the other three are on but not being used.
Do I have to do anything... or better... can I prevent the update until I want to do it?
I have four Ultras.
Did you mean to post this in an Amp Ultra thread?
Oops, yes, it should have been posted in the WiiM Ultra thread.
Is it possible to update the firmware of WiiM Amp Ultra v5.2.739555 from a flash drive? WiiM Amp Ultra sees that there is a firmware update, but can't download anything from the Internet! The Internet is blocked in Russia.
Not that I’m aware of. Maybe raise a ticket and ask WiiM directly.
