WiiM Amp Firmware v5.0.814734 Update - Apr 23, 2026
Please review the WiiM Amp update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
5.0.814734 (In Progress)
Release date:
Apr 23, 2026
Highlights:
  1. Sub & Main Speaker Sync: Automatically aligns subwoofer and main speakers for improved timing at the listening position.
  2. Spotify Smart Play: Resume your latest listening session with a single tap.
Playback & Audio:
  1. Playback Latency: Reduced delay when starting playback.
  2. EQ: Improved responsiveness when adjusting and switching EQ settings.
  3. Line In: Fixed distortion during extended playback sessions.
Radio & Streaming Services:
  1. TIDAL Connect: Upgraded SDK to resolve unexpected playback interruptions.
  2. Soundtrack: Updated SDK for improved playback stability and performance.
  3. TuneIn: Fixed playback issues for certain stations and improved resume behavior after long pauses.
  4. Deezer: Fixed unexpected playback interruptions.
General Improvements:
  1. Wi-Fi: Improved network stability and enhanced compatibility with Wi-Fi 7 routers.
  2. HDMI ARC: Disabling automatic audio output now correctly keeps WiiM in standby and defaults to the TV speakers.
  3. HTTP Server: Improved concurrency and stability under high load.
  4. Audio Input: Fixed playback crash issues.
  5. Alarm: Fixed incorrect alarm and preset volume behavior.
  6. Roon: Fixed occasional crash issues.
  7. Alarm: Fixes BBC and vTuner alarms defaulting to the chime.
  8. Qobuz Connect: Fixed occasional playback stopping issues.
  9. TV Remote: Allows adjustment of the volume step using the TV remote.
I looked at upgrading to a WiiM Amp Ultra, but this WiiM Amp does everything well enough and I actually prefer that it doesn't have any screen.
I usually recommend this model over the others, especially if people own iPhones.
@WiiM Team Does this timing alignment happen automatically or do we need to re-run RoomFit to get the benefit? It's the 'at the listening position' that prompts the question as it could suggest a need for some initial feedback to do the alignment.
It is a separate procedure to RoomFit. It appears under Subwoofer settings. It will now use the phone mic or an external mic attached to the phone instead of the microphone built into the WiiM device. You perform the procedure with the microphone in the listening position.
Thanks for the great note! I'll have a go at it.
Don't forget to let everyone know once you've got it 😁
Maybe you all should go to the barber one more time beforehand, or at least give that bald spots a polish...
