Wiim pro + arylic up2stream
Giulio Gallozzi
Good morning,
I have a multiroom system at home with 3 arylic up2stream and 1 audiocast, I would like to buy a Wiim pro plus, does it work if I connect the three different brands and use the Wiim as the main streamer?
Thanks
Download the latest WiiM home app and if you can see all your current devices (which I expect you will as I believe they’re all Linkplay based) then you should be able to link them in a group with the WiiM Pro plus and use them to play what it’s playing.
