WiiM Pro Firmware v4.8.709965 Update - Mar 6, 2025
Please review the WiiM Pro update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
4.8.709965 (In Progress)
Release date:
3 / 6 / 2025
What's New:
  1. My Weekly Q Support on Qobuz: Play "My Weekly Q" playlist (requires app v3.1.4).
  2. Preset Enhancements:
    • Move presets (requires app v3.1.4).
    • Presets now work in slave mode.
  3. Soundtrack SDK Enhancement: Upgraded for a better listening experience.
  4. Wi-Fi Stability: Improved connection reliability, especially for mesh networks.
  5. Gapless Playback Enhancement: Fixed an issue that caused skipping when playing tracks shorter than 10 seconds.
  6. Playback Enhancements: Fixed playback crashes, resolved a 2-second audio loss issue with APE format, and improved Bluetooth playback stability.
  7. Resample Algorithm Enhancement: Upgraded the resample algorithm to ensure high sound quality when resampling to 96 kHz or lower.
Bug Fixes:
  1. Radio Paradise Fix: Corrected a playback failure issue.
  2. Pop Noise Reduction: Reduced pop noises when switching inputs.
  3. LMS Fix: Fixed LMS reconnection issue.
So far it seems to me that it depends on the idle time. If I don't look at the app for, say, 20-30 minutes, I get a black image regardless.
That indicates very aggressive power saving settings enforced by Asus. You might want to try the steps shown here:
Thanks, these functions are simpler for me, but I checked, everything is turned off.
Same problem on Google Pixel 6A (Android 15)...
And probably same solution. :)
Phone makers often whitelist certain apps (like e.g. WhatsApp) from their power management settings, but not the lesser known apps. Unfortunately, this is not always transparent.
Not sure about that since no battery saver is active on my phone. This "issue" came up with one of the latest updates btw (no such problem before)
Hi Gerry_Tang,
Apologies for the inconvenience!
Our Android engineers are aware of this issue and are actively working on a fix, which will be included in the next update.
Android has built-in battery management. It's nothing you would install as a 3rd party app.
If WiiM can work around this issue happening on some phones, that's even better.
