Wiim Pro - Is it worth for my scenario?
Mrz7kN
Active member
Hi all,
Wanted to get your view on this....
I have an HEOS integrated amp. Tidal streaming is done via BubbleUpnp on Android and MConnect via iOS. I am fed up with Tidal via HEOS - just dont like it.
Now I am thinking about getting a Wiim Pro, connect it to the amp and use native Tidal app to stream via Tidal Connect.
Is there any downside as compared to BubbleUpnp or MConnect?
I only have hifi subscribtion as my amp can not deal with mqa.
Thanks
Hi all,
Thanks
Hi Mrz7kN,
The WiiM Pro supports TIDAL connect and the MQA decoder is done on the WiiM Pro. You can get up to 24b/96kHz bit perfect audio even your DAC doesn't support MQA rendering.
