Wiim pro..Noise on the line out
gazza1101
Valued Contributor
I have a Wiim pro and the USB power brick(non wiim) expired overnight, the usb cable end was a bit blackened, i swapped out the cable and USB power brick and it still works, i ha e tried the optical out and it works as it should but the line out is hery noisy and a constant high level hum, is there anything i can do?
What voltage was the power adapter you were using? Was it a smartphone charger?
If you were using a power adapter with a voltage higher than 5V, that might have caused the malfunction. What kind of power adapter are you currently using?
Yes it was a phone charger adapter, lesson learned, at the moment I’m using an Amazon adapter and seems ok.
Is there anything I can do about the noise or just have to accept it?
Is the Amazon adapter for a Fire TV or something similar? Please make sure it outputs 5V and at least 2A.
I have another Wiim pro and swapped them about, i only get the noise on the trouble wiim:(
I just picked up the cheap-but-excellent Fosi Q6 DAC - It lists for US$85 and I got 20% off that. It has USB, Coax and Optical inputs and I'm using the optical connection to a WiiM mini. With my WiiM Pro, I would use the Coax connection to the DAC... but in your noisy Pro case, perhaps the optical connection would be less likely to conduct the noise.
