J jotap_66 Member Joined Dec 30, 2022 Messages 24 Feb 11, 2023 #21 I have just opened a support ticket
M Mrz7kN Active member Joined Jan 22, 2023 Messages 146 Feb 11, 2023 #22 jotap_66 said: How can I power off the device? JP Click to expand... As there is no power button or option in the app, you have to pull the plug to power it off.
J jotap_66 Member Joined Dec 30, 2022 Messages 24 Feb 12, 2023 #23 Mrz7kN said: As there is no power button or option in the app, you have to pull the plug to power it off. Click to expand... Thank you
M Mrz7kN Active member Joined Jan 22, 2023 Messages 146 Feb 14, 2023 #24 Mrz7kN said: Opened a ticket as per the suggestion above. Keep you posted. Click to expand... Just received an update and now the light dims as per standby time.
J jotap_66 Member Joined Dec 30, 2022 Messages 24 Feb 14, 2023 #25 Mrz7kN said: Just received an update and now the light dims as per standby time. Click to expand... What is your firmware version? Where are you from? I think the updates are from 2AM to 5 AM. I am from Spain (Europe) Thank you JP
M Mrz7kN Active member Joined Jan 22, 2023 Messages 146 Feb 14, 2023 #26 jotap_66 said: What is your firmware version? Where are you from? I think the updates are from 2AM to 5 AM. I am from Spain (Europe) Thank you JP Click to expand... The version is 4.8.507636 - Europe as well. Edit: Could be I got it earlier, but only realized now.
O onlyoneme Major Contributor Joined Oct 20, 2022 Messages 3,067 Feb 14, 2023 #27 jotap_66 said: What is your firmware version? Where are you from? I think the updates are from 2AM to 5 AM. I am from Spain (Europe) Thank you JP Click to expand... This is the default window for automatic updates, but OTA check is performed every hour.
J jotap_66 Member Joined Dec 30, 2022 Messages 24 Feb 14, 2023 #28 onlyoneme said: This is the default window for automatic updates, but OTA check is performed every hour. Click to expand... Thank you JP
J jotap_66 Member Joined Dec 30, 2022 Messages 24 Feb 14, 2023 #29 onlyoneme said: This is the default window for automatic updates, but OTA check is performed every hour. Click to expand... Thank you JP Mrz7kN said: The version is 4.8.507636 - Europe as well. Edit: Could be I got it earlier, but only realized now. Click to expand... Mine is older. 4.8.504937 JP
O onlyoneme Major Contributor Joined Oct 20, 2022 Messages 3,067 Feb 14, 2023 #30 jotap_66 said: Thank you JP Mine is older. 4.8.504937 JP Click to expand... Yours is still an old 20230118 build.
O onlyoneme Major Contributor Joined Oct 20, 2022 Messages 3,067 Feb 14, 2023 #32 Just be patient, you will get a new one sooner or later. Updates are being performed in batches. I'm still waiting for an update as well.
J jotap_66 Member Joined Dec 30, 2022 Messages 24 Feb 14, 2023 #33 onlyoneme said: Just be patient, you will get a new one sooner or later. Updates are being performed in batches. I'm still waiting for an update as well. Click to expand... Thank you very much JP
J jotap_66 Member Joined Dec 30, 2022 Messages 24 Feb 15, 2023 #34 Update received. Now it dims ok thank you JP
