I see a fundamental lack of knowledge. Why do you want to install a dual channel opamp instead of a single channel opamp? It will destroy your wiim and or opamp.Sorry. I thought the 1656 was the ideal one.... I don't know... And a poster suggested that the original opamp is bipolar and should be or must be replaced by a bipolar ?
I generally like the sound of MOSFETs or jfets better than bipolar so wondering about this
Just because the type number of the opamp is higher, it does not necessarily mean that it is better and it is not at all certain that it can be replaced.
If you are not aware of the type and function of the opamp, do nothing or replace it with OPA1611.
If you want a FET at all costs, you can try the OPA627 type. Many people have already replaced 5534 with 627 in various applications and it seems to work well.
I know OPA627 is 1029 less than OPA 1656
Search for it on google for OPA627 and OPA1655! for 5534 replace
No one can tell you the difference between an OPA1655 and an OPA1611 in a Wiim. You will always get different opinions.
What is certain and the consensus is that the OPA1611 is better than the 5534
