Hello everyone,
I'm using Jriver MC 28 and the WiiM Pro Plus as a DLNA renderer to Playback my music library at 384kHz/24 bit, via DLNA configuration Menu. I have a pretty various library of dsf, flac, ogg, mp3 etc., so i wanted to Output any File with the highest sampling rate as possibe.
I even tried 768/24 Bit through the DSP settings for DLNA in Jriver which kind of worked but i assume because of the Ethernet only being 100mbits, there was stuttering and Not an enjoyable playback possible, so i stick back to 384/24.
Unfortunately i'm sporadically suffering from a terrible 'pink noise' between music Tracks (native Format, Bit depth does not matter, e.g. 16 or 24 bit) while using those Render settings. Lately i listened for hours to my library without any issues but another day i had the "pink noise" issue between 10 mins repeatedly, which i cannot explain so far.
Because native dsd Support is missing so far for wiim pro plus (even though it was advertised for), i've been pretty happy with the PCM solution, would not be this problem. The sound via Line-out at those settings is great and i dont want to miss it because of this unusual behaviour.
I attached a Screenshot with Playback Details, maybe someone has an Idea or experienced similar Problems...
Best regards!
Best regards!
