WiiM Pro Plus Firmware v4.8.717458 Update - May 19, 2025
Please review the WiiM Pro Plus update release notes below. If you encounter any issues, feel free to reach out to us. This firmware update is being rolled out in stages, with devices updating sequentially over the next few days.
4.8.717458 (In Progress)
Release date:
5 / 19 / 2025
What's New:
  1. Queue Limit Update: Playback queue is now capped at 3,000 tracks to improve performance. Further optimizations are in progress.
  2. Enhanced DSD Playback: Resolved stuttering during multi-channel DSD file playback for smoother high-res listening.
  3. Stabilized Wi-Fi Connection: Updated the Wi-Fi driver to enhance connection stability.
  4. Device Discovery Enhancements : Improved stability and connectivity for WiiM Home, Spotify and TIDAL apps.
Bug Fixes:
  1. Plex Playback Fix: Resolved playback failure when Secure Connections is set to "Required".
  2. TIDAL Connect Fix: Addressed the issue of track skipping delay and corrected track duration when using the HTTP API.
  3. Optical-in Playback Correction: Fixed swapped audio channel issue for optical input.
  4. General Performance: Stability improvements and behind-the-scenes optimizations.
wait and see
Yes. Personally, I'm glad the firmware update has been pulled. I would rather wait for a stable functioning version over a rushed, problematic release.
This was the eventual reply to my ticket:
"Due to the significant changes included in this update, the rollout for the WiiM Pro Plus is being carried out in stages. Currently, only a small number of devices have been upgraded to the latest version, and we are continuing to monitor the process.Please wait patiently for a while."
I think that misses the point in why it’s visible as a beta, not public release.
I have two WiiM Pro Plus'es.
One of them I was able to upgrade, but not the other.
Is the upgrade queue based on MAC address or serial number, or something :)
Something ;) There’s no discernible pattern to firmware releases
I have no confirmation from WiiM that this firmware version is a Beta release, although I have asked numerous times for clarification here and in my ticket. To date, that clarification has not been forthcoming. However, I think it's safe to assume that this was only a Beta release, or a rushed release with numerous bugs, which seems to be happening a lot of late. Happy to wait for a working version, as I said. :)
The main thing is that it doesn't cause more problems...
I hope,( having had some perspective on the Wiim updates concerning audio , and here, impact on the input Toslink,) ,that this part will have been seriously checked...
and the rest of the "audio"
Very happy to report that my WiiM Pro Plus has seemingly updated successfully, and remarkably, the lock screen controls have returned as well.
Thank you @WiiM Team
I registered a support ticket with WiiM regarding the different upgrade dates for my two WiiM Pro Plus'es.
This is the answer I got:
"Before today, the firmware update for the WiiM Pro Plus had only been rolled out to a limited number of devices. The full release began today. We took this phased approach to ensure there were no major issues before making the update available to all users."
Case closed :)
Mine just updated this morning. Tidal Connect no longer connects to my Wiim Pro Plus
It seems to be a Tidal issue. None of my others streamers work with TC.
Firmware update this morning whacked out my pro plus. It continuously rebooted and disconnected. I couldn't reset it to re-add either. I finally got it connected just long enough to have to restore to factory settings!!
Hi @destructivedez ,
Sorry for the inconvenience!
Please help us investigate this issue by sending feedback through the WiiM Home app: go to the More tab and tap Feedback. Our engineers will look into it promptly once received.
