Short and to the point!!
Best connecting a small headphone amp to the output from the Pro Plus.thank you but the point is here. How listen to my Beyerdynamic D770 80 Ohm?
See Pro 2 in my sigthank you but the point is here. How listen to my Beyerdynamic D770 80 Ohm?
Very interesting. It Has got an internal DAC. If I connect via USB or coaxial cable the Mac of WiiM is passed out and it will work only the FiiO Dac?I know this one. Both options.
FIIO K5PRO – DER KLASSIKER, NEU DEFINIERT
FiiO K5 PRO - HOCHWERTIGER DIGITAL-/ANALOG-WANDLERfiio-shop.de
Great, but it hasn't analogical inputBefore purchasing the Fiio K11 I was considering the Fosi Audio SK02.
Fosi Audio SK02 Desktop DAC/Headphone Amp
The SK02 employs a minimalist and stylish design language. Despite its small size, it boasts mighty features. It supports DSD256 and PCM 32bit/384kHz high-resolution decoding, along with 3.5mm single-ended and 4.4mm balanced headphone outputs.fosiaudio.com
True, and I didn't mean to suggest otherwise.Great, but it hasn't analogical input
