Short and to the point!!
Best connecting a small headphone amp to the output from the Pro Plus.thank you but the point is here. How listen to my Beyerdynamic D770 80 Ohm?
See Pro 2 in my sigthank you but the point is here. How listen to my Beyerdynamic D770 80 Ohm?
Very interesting. It Has got an internal DAC. If I connect via USB or coaxial cable the Mac of WiiM is passed out and it will work only the FiiO Dac?I know this one. Both options.
FIIO K5PRO – DER KLASSIKER, NEU DEFINIERT
FiiO K5 PRO - HOCHWERTIGER DIGITAL-/ANALOG-WANDLERfiio-shop.de
fosiaudio.com
Great, but it hasn't analogical inputBefore purchasing the Fiio K11 I was considering the Fosi Audio SK02.
Fosi Audio SK02 Desktop DAC Headphone Amplifier
The SK02 employs a minimalist and stylish design language. Despite its small size, it boasts mighty features. It supports DSD256 and PCM 32bit/384kHz high-resolution decoding, along with 3.5mm single-ended and 4.4mm balanced headphone outputs.fosiaudio.com
True, and I didn't mean to suggest otherwise.Great, but it hasn't analogical input
fosiaudio.com
Good to know, thank you. Could you please tell me what cable rca to headphone you advice to me to use?There is plenty of volume available for my Grado, Sennheiser, and Sony headphones, and I have never needed to go above 75% on the WiiM volume setting sliders in the WiiM Home app.
As you said, when I connect my Panasonic RP-HD500 headphone to the WiiM mini, they are loud enough even at 40%.I have used various different headphones with a WiiM Mini, using the 3.5mm audio out, and have also connected headphones to a WiiM Pro, and WiiM Pro Plus, using the RCA audio out, with suitable cables.
