Wiim Pro Plus not working - solid Green Light for 10 sec then no light for 3 seconds.
Imeasure
Wiim Pro Plus not working - I get a solid Green Light for 10 sec then no light for 3 seconds and it repeats.
Can't connect to it.
Any ideas appreciated.
I have had this unit running for over 6 months.
Does the WiiM app show Pro Plus?
The green LED may be due to Bluetooth. Check that there is no Bluetooth connection between the phone and the Pro Plus.
Also, unplug the device's power cable, connect it after a short while and reboot.
Have you been using this "high powered USB adapter" throughout this six months plus period?
If so, I wouldn't have much trust in it for any application.
