Wiim Pro Plus Eq not working on Line OUT
armix
Hi ,
I have bought the Wiim Pro Plus to connect it to Wiim Amp for the better DAC. LINE Out ( RCA ) from Wiim Pro Plus to Line IN(RCA) to Wiim Amp. When i stream music from Spotify and try to apply an EQ ( preset ) or Custom it doesnt change the music sound at all. Can someone enlight me on this ? When I was playing music thru Wiim AMP Only the EQ worked.
Best regards,
Andrei
Streaming from Spotify to Wiim Pro Plus and using the Wiim AMP it works
Now you eventually lost me.
I thought that streaming to the WiiM Pro Plus (using Spotify Connect) and using the WiiM Amp as a power amplifier was the scenario that didn't work?
And one more time, even if it's been said before: If you connect the line out of the WiiM Pro Plus to the line in of the WiiM Amp instead of using the WiiM Amp alone, the what you do is adding the DAC of the WiiM Pro Plus and the ADC of the WiiM Amp to the signal path.
One additional DAC. One additional ADC. The DAC of the WiiM Amp is still in use. There's no way around this as long as you are using the WiiM Amp's speaker outputs.
Your new setup:
Spotify Connect =>
[(WiiM Pro Plus) digital network streaming input => digital processing (EQ, volume, etc) => DAC => analogue line output] =>
[(WiiM Amp) analogue line input => ADC => digital processing (EQ, volume, etc) => DAC => power amp section => speaker binding posts] =>
[speaker cables] =>
[(speakers) binding posts => crossover => speaker drivers]
Your previous setup:
Spotify Connect =>
[(WiiM Amp) digital network streaming input => digital processing (EQ, volume, etc) => DAC => power amp section => speaker binding posts] =>
[speaker cables] =>
There's really nothing to gain from the new setup if all you want.to do is playing Spotify in ... errr ... "better quality".
If you still just want to know what's going on (which I could understand), @Wiimer proposed pretty much what is possible.
The most important thing is that EQ can be different per input, but @Wiimer had that covered, too.
Your new setup:
Spotify Connect =>
[speaker cables] =>
Spotify Connect =>
[speaker cables] =>
And maybe a misunderstanding that EQ and DAC is related?
Thanks all for the help. Well this way you always learn something. I shouldn’t have bought the wiim pro plus and used the wiim amp as it is. Before this i had another setup Cambridge axa35 + node but the AXA is just an amp no dac built in
I removed the Pro Plus from the chain and its all good now. I will sell it and get back some of the investment. Thanks again !
The WiiM Pro Plus is still a fabulous streamer, useful for many things (including multi-room music).
There's just no way to improve whatever technical aspect of the WiiM Amp. The WiiM Amp Pro and the WiiM AmpmUltra do feature techicall better DACs than the original WiiM Amp. But upgrading means selling one and buying the other.
