Use WiiM Pro When the machine,Use Foobrt2000 Of Upnp/DLNA The function is normal.,Use WiiM Pro Plus The machine, use Foobrt2000 Of Upnp/DLNA Work Can,Foobrt2000 There will be no sound when playing.。
Use WiiM Pro When using the machine, use Foobrt2000 Of Upnp/DLNA The function is normal, use WiiM Pro Plus The machine, use Foobrt2000 Of Upnp/DLNA Function,Foobrt2000 There will be no sound when playing.。
When using WiiM Pro to use the machine, the Fobrt2000 function of Upnp/DLNA is normal. When using WiiM Pro plus the machine, using the Upnp/DLNA function of Foobrt2000, there will be no sound when Fooft2000 is played.
When using the WiiM Pro machine, the Upnp function of the Fofrt2000 player software is normal; when using the WiiM ProPlus machine, the UP np of the Fofr t2000 player software is abnormal, and the Fo frt2000 cannot hear the sound of the song.
