I'm new here. I tried an Arylic S10 and the device was mostly unresponsive to the App while playing with it for over an hour so I returned it. It would have met all of my needs if it worked properly.
I then ordered a WiiM Pro and much of the same issues continued. Disappointing, so I started a search for another brand/device, but then I tried it again and it worked about 1.5 hours later! My Android phone found the WiiM and the Wiim found my network drive which is a Samsung 1Tb SSD connected to my Asus AX router (using WiFi).
I read later that the Arylic and the WiiM are co branded (or to that affect), so I also tried the Arylic app on the WiiM and it worked, but although the WiiM is not a not what I would called a feature rich app, the Arylic app is way behind in usability, functions, and connectivity.
The Wiim Pro would be great if it works all of the time, but like others, I get the random "Device not Found" and "Search your Media Server" (two separate issues) and you can not proceed without rebooting or restarting some hardware (WiiM, router, phone). I don't know what causes the problem and I don't know what steps I took fix it, but if it happens often, the device is useless.
I also have the HiByMusic app on my Android phone and it ALWAYS can connect, browse, and play my music from my network drive, so I know my router/SSD server is not the problem.
I am not an expert at any of this streaming technology, but are there any apps other then WiiM or Arylic that we can use to browse and play music on the Pro?
The concept of this device is great. Music is not interrupted by calls, tests, or notifications, and you can use the same library in other locations in your home. If the connectivity issue gets sorted out, I would buy more devices, including the Mini.
So far I have three suggestions for the app (that don't effect actual playback).
1. When listing Artists, Albums, etc, there should be an A-Z bar on the right side of the screen for large libraries to jump ahead. The local phone track listing has this.
2. You should be able to disable (from listing) some of the services that you do not use.
3. When you press Home Music Share it has you choose your Router and "Browse, Music, Pictures, Video". Most users will only have one router, so it would be better to, after you press "Home Music Share" it skips asking for Router and "Browse, Music, Pictures, Video", and goes directly to the Music screen. The Music screen has Artists, Albums, etc. You could put a button on that screen for the other Pictures, Videos, etc options. Basically most users will use this to stream music and it would be nice to just press Home Music Share and go right to being able to search your library.
I've had this device three days and had multiple connection issues. This morning everything was working fine and I seen there was a firmware update. I played with it several times without a problem but then got the "Search your Media Server" error. I couldn't go further without doing something. I then started to post here. While writing this I tried several more times and the error continued, but like I said HiByMusic did work.
Just as I am about to post this, the app now works again. I am baffled as to the problem or what fixes it.
Thanks for any help!
