WiiM Sub Pro – Glitchy behavior and inconsistent settings (Wired + Ultra setup)
no.regrets!
Hi everyone,
I got the Sub Pro over the weekend. It’s my first sub, so apologies if I’m missing something obvious or if there’s a simple fix I am not aware.
So far, the only stable connection I can use is wired, since the wireless drops out often.
Wired works around 80% of the time, but a few issues keep showing up:
  • The sub can’t be turned off – even when set to Off, it keeps playing.
  • Levels change frequently, depending on input. Switching from Radio Paradise to Hotmix or from Spotify to TV always needs manual adjustment. Sometimes, levels even go up on their own during the same input/station play.
  • The crossover limit jumps between 110 Hz and 250 Hz without any clear reason.
  • The phase control doesn’t seem to have any audible effect, even at higher volumes.
  • The speakers play bass option disappears randomly from the app.
Setup: WiiM Ultra >Yamaha S-501> Mission speakers >WiiM Sub Pro (wired).
Ultra and sub are updated, and I did a factory reset after.
At this point, I will have them turned off, too much messing about, and if I am not at home family is not able to set it up.
If anyone has seen similar behavior or found stable settings that work with the Ultra + Sub Pro setup, I’d really appreciate any advice or confirmation that this is known behavior.
Cheers!
Hi everyone,
Cheers!
Please try connecting your Sub Pro to the “Sub Out” port on the WiiM Ultra and check the result. Alternatively, you can pair the Sub Pro with your Ultra wirelessly.
If the issue persists, please submit a support ticket through the WiiM Home App, and our team will assist you shortly.
Thank you for your patience and support!
This is the current setup. Sub out from ultra to sub pro. And with that connected, I have all the issues I described. The ticket has been created.
Thanks for the fast reply!
All I wrote above stands.
I can only add that now, roomFit is either not accessible, or when you try to run it drops out.
Ticket #543802 was created a few days ago. Ultra and Sub Pro are up to date, and I did a factory reset after.
It is the software side that is not working. I sure hope you will get some new patch for it soon :)
Hi no.regrets!,
Thanks for submitting the ticket. Our engineers are working on this now and will keep you posted on the progress. Thank you again for the patience and support.
