My Plus just updated and does show in LMS too. And here’s the rocket…A new 4.8.528649 FW for the Plus with declared squeezelite support. Although my LMS cannot see my upgraded Plus.
I have a bad day today.My Plus just updated and does show in LMS too. And here’s the rocket…
However, cover art doesn’t seem to be showing for Radio Paradise, but does for Qobuz. I’ll let it run a little then submit a ticketI have a bad day today.
My Plus behaves more consistent here...However, cover art doesn’t seem to be showing for Radio Paradise, but does for Qobuz. I’ll let it run a little then submit a ticket
It does now on track change. No big deal…My Plus behaves more consistent here...
No cover art for me at all on iOS app, so it's not related to the device.It does now on track change. No big deal…
Cover art for RP appears when Chromecasting from the native app. Not for the RP version in WHA though, just a station logo, as normal.However, cover art doesn’t seem to be showing for Radio Paradise
Sorry, should have expressly mentioned I was using RP from LMS with the new Squeezelite firmware - seems to sort itself out on track change.Cover art for RP appears when Chromecasting from the native app. Not for the RP version in WHA though, just a station logo, as normal.
Is the filter apply only on pro plus not regular?My Plus just updated and does show in LMS too. And here’s the rocket…
Only Plus that I’m aware of - perhaps the DAC in the Pro/Mini doesn’t support such compared to the DAC in the Plus.Is the filter apply only on pro plus not regular?
PEQ behavior has changed a bit since the previous beta release, it's fully transparent with 0 dB gain flat settings.
Also GEQ has changed comparing to previous official FWs, no longer -1 dB pregain thus also fully transparent with 0 dB flat settings.
Volume limiter works as before, ie. -3 dB for every 5% decrease. In case of GEQ mode it's just even more important to control the level and compensate the positive gain as there is no pregain applied by default. It was equally important in PEQ since the beta.I take it that’s good news and will put to bed the negativity around this? Where does the volume limit setting fit around this?
And maybe @Smartplug can ask when it’ll be betterVolume limiter works as before, ie. -3 dB for every 5% decrease. In case of GEQ mode it's just even more important to control the level and compensate the positive gain as there is no pregain applied by default. It was equally important in PEQ since the beta.
Some people (guess who? ) can say it's worse than before.
