Amp Ultra vs Ultra/Vibelink?
Sorry, I'm not sure I understand the context.
Am I correct in thinking you are referring to the Ultra/Vibelink and if I use RCA between the two (i.e. using the DAC in the Ultra) I get 60w output from the Vibelink. But if I use an Optical connection (which uses the DAC in the Vibelink) I get 100w output?
Totally correct
I am in a similar position deciding which way to go!
The Amp ultra is slightly more powerful, according to true technical measurements recently released, as it has twin Ti amp chips. (although WiiM will not confirm how they are implemented) WiiM has decided to measure each in a slightly different way, and listing them both with the same power! The range hierarchy is slightly odd and haphazard as you pay perhaps an additional cost (USP for existing Ultra owners!) for the Vibelink as it matches the ultra, but it in fact doesn't, being a slightly different colour, size and volume knob alignment! The colour and volume knob is sloppy, as it had no cost implication. Why!
I suspect they will sound similar, I think the Vibelink is slightly over priced in the UK/Europe as it is $299 (£220) in the US and £319 in the UK. But once the existing Ultra owners have purchased and sales slow a bit, it will likely be on sale. Although they have already updated it, as it now has the colour coded banana plug terminals (as the Amp Ultra) They will likely improve colour matching as new batches are produced too, but the volume knob misalignment you may have to live with.
Just read the product managers response to multiple prospective purchasers queries, and the Amp Ultra he has confirmed has superior sound quality! as one would expect with Twin amp chips! And cheaper too!
Leaving aside exchange rates, sales taxes etc, here's a little table I put together to guess at what the Amp Ultra might cost in the UK and AU based on existing known prices. As I said, leaving aside currency etc, the UK number is consistently 20 more than the USA number for the more recent kit, while the AU number is close to 175% of the USA number and the EU 70 more than the USA. Just guesses though...
Thing is I will probably get the vibe as I have an ultra and require the phono stage however I still have arguments in my head over speakers 😜
Whereas I know (to me) they are indistinguishable.
3 key reasons why some might say the ultra/vibelink pairing is better, but why I think the amp ultra is better.
Best of all, as they are my reasons no one can say I'm wrong.
Misguided maybe, but not wrong. :)
1) Vibelink has a pure analog input, no adc applied.
Yet I think the vibelink analog input sounds significantly worse than digital. For me this makes the possibility of using an external dac (or even the ultra dac) or full analog path (e.g. vinyl bypassing the ultra) a moot point.
2) Ultra has a headphone socket.
While I have said, and still think, the ultra's headphone output is good for a device at this price point along with everything else it offers, any 'serious' headphone listener will want better. And better can be had for not a lot of money. Hoorah for usb out.
3) Separates / flexibility.
I can fully appreciate the flexibility two units provide, and agree. But...
If one of the two units is the vibelink then compared to the amp ultra the actual amplification part is (almost) the same. Well, sound wise I cannot tell them apart, so the same is close enough. An ultra and something completely different I get, but an ultra + vibelink vs an amp ultra... six of one and half a dozen of the other.
Although separates does allow you to mix things up / move things around later on. So maybe a draw here after all.
Regardless, whichever you choose I doubt you'll be disappointed, so enjoy!
3) Separates /flexibility.
Separate units is the draw for me as my experience with Sonos has soured me on one box solutions
I can swap parts out if problems arise the only part that is causing me issues are my speaker choice
That is the only part I intend to keep whatever happens as I am going floor standing and don’t live in a large house so cannot repurpose them
Seeing as you already have the ultra, the vibelink makes perfect sense.
Now, how about a new thread to help you buy your forever floorstanders...
We excel at spending others' hard earned.
No, if you connect Ultra to Vibe with RCA obviously you are using the DAC of the Ultra, and less power output from the Vibelink.
Otherwise if you use the digital connection between Iltra and Vibe you are using the DAC of Vibe and full output power.
Do you have a link to the response?
The dual TI TPA3255 are used in parallel, so there is no power increase to be expected into 8 Ω or 4 Ω loads. A single TPA3255 can handle that well enough. The PBTL configuration will really start to shine into lower loads.
Generally speaking the dual chip configuration can also potentially provide a lower output impedance, but then there are also the output filter coils and the PFFB implementation ...
Obviously, WiiM did not even attempt to pick a PSU powerful enough to double the power output into 2 Ω compared to 4 Ω. This would surely have required a much bigger case, for cooling and for the PSU itself.
Still waiting for more detailed measurements.
Thanks, I got it the wrong way around - now corrected (hopefully).
