Audio dropout
JJK1954
Hello:
I am suddenly receiving split second audio dropouts on WiFI. My connection is solid. Any thoughts?
I've got something similar on my new ultra. If the wiim has been idling a while, the sound drops for a few secs, every 90 secs or so for the first 3 or so tracks of whatever album I play. Connected to pc via plex pro, WiFi working fine with good signal. It's like it's looking for updates or something and then stops trying. Ideas anyone.
Best idea is to submit a ticket to WiiM when this happens so they can inspect your log for potential issues.
You could try a power cycle your router then the WiiM, and turn off Preferred DNS, IPV6 and wi-fi roaming in your device network settings to see if that helps.
Eventually your WiiM does it's duty job of calling home frequently. To avoid homesickness...or so. But pssst...Security and privacy questions are obviously not a priority for many here and mentioning that was never welcome. 😂😂
Thanks for that. I'll experiment a bit more first (looking for my long ethernet lead!). Now discovered it does it with streaming radio as well, but for longer! Must be to do with the WIIM and my router/modem.
