Audirvana/Mac Mini/WiiM Ultra help! (noob)
Gregoire
Trying to trial Audirvana on my Mac Mini and when I try to connect it to a player, I have two choices... UPnP on my Marantz AVR (which works well!) and Chromecast WiiM Ultra (which doesn't work). I'm guessing it would work if the connection was UPnP but that isn't a choice. thoughts?
Go into the WiiM Home App, and the Mac Mini should be there as an UPnP/DLNA Source. But then, you will be using the WiiM App to select Media or Playlists...
