Hello there,
I have some questions about my setup:
I use the Wiim Ultra inbetween a Power Amp (Pro-Ject DS2 Amp Box) and an AVR (Marantz Cinema 70s) as a Preamp (Connection via RCA from the Marantz Front Preouts into the Line In of the Wiim Ultra, Volume Set to 100%). I use Audyssey via the Marantz for Measurements. Is the right way to go to leave the EQ Settings in the Wiim Ultra to "Flat" or should I use also the Room Correction for the Line In Input?
The Results of the Audyssey Measurements show a big difference in the Speaker Distance Section (PreOut Fronts 7m, the other Speakers 2-3m), so I guess this is the Latency then? Or is there an Option to reduce the Latency? The Front Speakers are also quieter than the other speakers, so that Audyssey raises the gain after the Measurements, should I better use the gain function for the line in input the Wiim Ultra to level all speaker?
Sorry for my bad english
