The same for me… I have a WiiM Mini connected to the Ultra’s and the same problem. I have the latest software versions - WiiM App Home & WiiM devices.
It would be really nice to make it working as expected. Now when I use AirPlay on Mini’s, I have to change the input source on Ultra’s to “Optical In” manually…
I also use HDMI ARC input.
I don’t use the HDMI input, but do use the Optical input, and the auto sensing works well for me.Same for me, sent a ticked about it and received info that with HDMI input active Optical In auto-sensing does not work. I don’t know the reasons, it was not explained and I am afraid it wont be fixed. They advice to physically disconnect HDMI cable when not used which is an absurd.
For me Optical In auto sensing doesn’t not generally, not only on active HDMI input and I have to switch manually to Optical and from Optical. And it sucks having in mind convenience of auto-switching of rest of inputs.
Krzysztof
In previous firmware versions the HDMI ARC and optical auto sensing was the same. This may indicate that they use same hardware? This could make it impossible to automatically detect if the input is HDMI or optical.Same for me, sent a ticked about it and received info that with HDMI input active Optical In auto-sensing does not work. I don’t know the reasons, it was not explained and I am afraid it wont be fixed. They advice to physically disconnect HDMI cable when not used which is an absurd.
Krzysztof
Too bad. This is a big flaw.In previous firmware versions the HDMI and optical auto sensing was the same. This may indicate that they use same hardware? This could make it impossible to automatically detect if the input is HDMI or optical.
If there is only signal on one of the inputs there is logic that can find the active input. With signals on both that is not possible.Too bad. This is a big flaw.
Probably inside of the device the hardware is made in such a way that the digital signal from HDMI and optical signals go through the same channel and it is difficult to detect at the processor level where does it come from... :/
However, in this case, if it is unrepairable, then in the WiiM Home application it should not be possible to activate auto sensing of both HDMI ARC and Optical In. There should be one of them to choose from. Otherwise, it is misleading.
I seem to recall WiiM saying that the same hardware was used when this was first brought up a while agoIn previous firmware versions the HDMI ARC and optical auto sensing was the same. This may indicate that they use same hardware? This could make it impossible to automatically detect if the input is HDMI or optical.
What about Line In ? This is the same case ?
If could add a feature to automatically switch to Wi-Fi when the WiiM device enters standby mode, this would resolve many of these issues. I previously requested this here.Same issue. Won’t auto detect optical from my apple AirPort Express. Super frustrating as it’s blocking seamless verbal “Siri play x on stereo” command for the family. Was going to swap to wiim pro, but seeing from the chat it’s the input with HDMI, not the device.
Chat GPT is recommending an optical “keep alive” dongle, but I’m not sure.
It doesn’t look like something difficult to do. Even now you can just setting this by Home Assistant for example. I mean that you can make an automation with auto WiFi source switching after standby mode detected.If could add a feature to automatically switch to Wi-Fi when the WiiM device enters standby mode, this would resolve many of these issues. I previously requested this here.
Currently, some inputs can't be automatically switched by auto-sensing while the WiiM device is idling.
As far as I know, auto-switching is not possible for these two.
1) HDMI to Optical-in
2) Optical-in to Bluetooth-in
Is it technically difficult to switch these automatically?
If so, I have one suggestion. That is the option to automatically switch input to Wi-Fi when the device's input is HDMI or Optical, after the audio has been stopped.
This is provisionally referred to as the 'Auto-Return Wi-Fi' function.
The main operation of Auto-Return Wi-Fi is as follows.
1) When the TV...
- Wiimer
- Forum: General WiiM Home App & Device Feature Requests
I hope the @WiiM Team and @WiiM Support will look into this.
