slartibartfast
- Apr 18, 2024
I assume when it does come out it will be based on the just released firmware.I don’t think it’s out yet
I have a TRRS to USB adaptor as well. I am starting to wonder if it affects the frequency response of the iMM6 microphone.I'll sign up as soon as I'm back home tomorrow
Will this use the phone built-in mic (pixel 8 pro in my case) or external (I have an IMM6 with some random/unbranded USB jack adaptor) ?
Well, afaik, they do contain an ADC (and a DAC) unless I'm mistaken so it's quite possible if they aren't implemented well...I have a TRRS to USB adaptor as well. I am starting to wonder if it affects the frequency response of the iMM6 microphone.
this is why the usb version could be expanded rather, by integrating a quaibration conciderant of [micro-adc].....Well, afaik, they do contain an ADC (and a DAC) unless I'm mistaken so it's quite possible if they aren't implemented well...
Any idea how to test it? Mine is Dukabel from Amazon. I suspect I would need a cable with a TRRS plug as a minimumWell, afaik, they do contain an ADC (and a DAC) unless I'm mistaken so it's quite possible if they aren't implemented well...
How did you get RC on Android? I'm still waiting for the beta firmware.Working here just fine. I limited correction to 40-300hz, using Harman curve. Measurement using internal mic on Pixel 8a was reasonably close to using ARC USB mic. I'm assuming the External mic is a bit more accurate so went with those adjustments. Pretty well done. Only bug is that the correction limit doesn't seem to work, I had to manually turn off adjustments above 300hz.
You downloaded the beta app ?How did you get RC on Android? I'm still waiting for the beta firmware.
Nope didn't even know about it and nobody else has mentioned it working. Where does the beta app come from?You downloaded the beta app ?
It's been added to the first post in this threadNope didn't even know about it and nobody else has mentioned it working. Where does the beta app come from?
Hidden in plain sight thenIt's been added to the first post in this thread
Hmm. Measuring pretty freaking flat there in the bass. No doesn't seem right.The results look extremely dodgy as well. This is on a Pixel 3a
It is just an iMM6. I have used it with REW on PC and Audiotool on Android. I can't see any adjustable settings for room correction either.Have you used other analyzer app to verify that the IMMC-6 is collecting sound?
At 4:00 in the morning, I woke up to use the restroom and the event had already started. I am not sure if I should go back to bed again or start the test now.![]()
What does the internal mic measurement look like?It is just an iMM6. I have used it with REW on PC and Audiotool on Android. I can't see any adjustable settings for room correction either.
It is a couple of posts backWhat does the internal mic measurement look like?
Sorry, thought that was the external mic.It is a couple of posts back
Post in thread 'Beta Test: Room Correction for Android' https://forum.wiimhome.com/threads/beta-test-room-correction-for-android.4000/post-64951
When the external mic was plugged in room correction still used the built-in mic.Sorry, thought that was the external mic.
